What weight oil do the 2003 mercruiser 350 tow mag use?
Marine oil vs. auto oil???
Originally posted by chpthril View PostThe way everyone feels about marine oil, is how i feel about how Synthetic oil and "Premium" gas is marketed. They cost more and there is no real benefit over conventional oil.
No offence, I just got a laugh out of it that in the same post you said "dont get ripped of" and "I use full Syn".I don't want to go to work, take me wake surfing instead!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by dom w. forte View PostWe have used Kendall oil for over 50 years and it is a synthetic blend, we recommend due to our climate, change oil every 50hrs or 6 months and only use the manufacturer weight.
The "manufacturer's weight" in my case (2009 PCM EX-343 engine) is 15W-40 GF-4/SM. Every 15W-40 oil I can find is diesel rated (C*, not SM or S-anything). All the GF-4's (and some GF-5's) are 10W-40, etc. I can't find all of the things PCM wants in a single can.
Ambient temps here in the summer are over 50F.
So... what do you recommend?
Thanks!
Thanks!
Originally posted by jbort View Postyes I do and oil cost difference is small in the overall scheme vs ruined engine. Marine engines work harder and run hotter frequently for longer periods. A belt won't cook the engine, wrong oil will. I'm sure otehr memebers will pipe in too.
My boat runs around 140f and my truck runs around 190f.Tige, it's a way of life!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by dom w. forte View PostThe diesel rated oil is what we use , and will work fine for you, I would still stay with the 15w 40 and a synthetic blend.
I have sent a message to PCM, via their website's "Contact Us" page, asking if they agree. This is the second inquiry I have sent them about winterizing (the other was whether I should fog the cylinders of my CAT engine). They have never, ever responded to messages submitted in that way despite their website's promise that they will, but I'm still hopeful.
Thanks!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Digging around, I found this on Mobil's website:
>>From an engine performance viewpoint, the API CJ-4 oil should provide adequate protection. But this heavy-duty viscosity grade has a higher level of phosphorus than typical ILSAC GF-4/API SM oils designed for today’s light-duty trucks and cars. This higher phosphorus level can potentially shorten the life of expensive emission control equipment including the catalytic converter. We recommend you stick with the oil recommended in your owner’s manual.<<
...from:
https://www.mobiloil.com/USA-English...s_Engines.aspx
So it may work great in normal exhaust engines, but my in CAT equipped engine it doesn't sound like the best choice.
Only "Ralph Lauren" designer marine oil touches my boat engine sold at fine establishments. All of the dinosaurs that the oil is made from has been screened to ensure that they are purebred dinosaurs. I will never use an oil that can be sold at Walmart or Kmart.
For the record, I do use marine oil, but wouldn't have a heartache over using auto oil.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by Moki View PostFor the record, I do use marine oil, but wouldn't have a heartache over using auto oil.
Two solid sources - Dom and Pennzoil - have said diesel rated (CJ-4) oil is fine. But I'm concerned about PCM and warranty issues... their owner's manual is quite specific.
From the manual:
The following chart shows the recommended oil viscosity
for various ambient temperature ranges:
Prevailing Ambient Recommended A.P.I.
Temperature Classification & Viscosity
Above 50°F SAE 15W-40 “GF-4/SM”
Below 50°F SAE 5W-30 “GF-4/SM”
IMPORTANT: The use of oils which contain “solid”
additives, non-detergent oils or low quality oils
specifically are not recommended.
WARRANTY NOTICE: PCM Engines reserves the right
to refuse warranty on part(s) and/or engine(s) damaged
by using improper fuels and engine oils.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Followup: We have a couple of threads running on this topic, but just so everyone gets the data I'm crossposting this update.
OK, I now have six quarts of the proper oil. It comes with a story.
After calling every auto shop around, and West Marine, to no avail I started calling boat shops. Several said they just use diesel rated 15W-40 oils.
However, the MasterCraft dealer - one of only two PCM certified shops in the entire region - had more to tell. He said they are not satisfied using diesel oil in a gasoline application. They've only had their PCM certification for a very short time (they got it because they are also the Centurion dealer) and they are careful to toe the line when it comes to PCM's requirements. They could not find the proper oil anywhere, so "I'm not surprised you can't find it either."
To remain in compliance with PCM's specs, they contract directly with Mobil and have the proper 15W-40 GF-4/SM oil delivered in 55 gallon drums. The shop manager drained six quarts into a couple of containers and sold them to me for $30.
So the proper oil IS out there. If you can't find it at retail, check with local PCM dealers and see if they're buying it in bulk. If they're not, ask them what they use. You might be surprised!Last edited by IDBoating; 10-08-2010, 04:06 AM.
