I've been doing my own oil changes for the last 5 years on my 2002 21v w/ a merc 350. This year I noticed a few strange things.
I checked the oil level (almost to the "F") and then I warmed the motor up until it was hot. I then used the drain tube out the bildge hole. This time I decided to measure how much came out. The boat calls for 5 qts but after 4 hours of draining only 3 qts came out and that includes the oil from the old filter. I raised and lowered the bow to see if that would change anything and it did not. It also seemed to come out much slower this time. I even blew into the hose to see if anything was clogging it and it was clear.
I don't want to run it low on oil but after putting 4 qts back in, it is over the full mark. I wonder if that will drop a little after the motor is ran?
It seems like all the old oil did not come out but since the oil drain tube is connected to the bottom of the drain pan I thought it would get more that 3 qts.
How much oil are you guys emptying vs. the capacity?
