What oil you guys using?
    Just curious as to what is the best oil to be using for your TIGE. Thought I would ask the experts...
    I have the 350 mag MPI by the way...
      X2 ???
        Use a Marine Grade Oil. Here is an article from Boating Life Magazine.
        http://www.boatinglife.com/article/M...ding-Motor-Oil
          I use Castrol marine oil. Straight 30wt.
            what brand? What weight? What filter?
            just trying to see what people are using to compare to what I am using
              used the merc synth blend. you should be able to find merc filter part# online. and get at any of you local merc part dealers.
                Amsoil marine 10w40.
                  Does Royal Purple make a marine oil?
                  Everyone is entitled to their own opinion. It's just that yours is stupid.
                    I was thinking the same. How long will you run until you change it?
                      Pretty sure they do. I know they have been heavily advertising on boattest.com for a while. In fact, boattest posted some articles claiming that they ran tests showing the Royal Purple significantly lowered the fuel consumption and noise levels from engines. Seemed pretty amazing, but I don't know how much the advertising dollars may have influenced the "testing".
                      Edit:
                      Here is the boattest article: http://www.boattest.com/resources/vi...px?NewsID=3844
                      And, after looking at their website, while they promote it's use in marine applications, it looks to me that it is their standard motor oil, not a marine-specific blend. http://www.royalpurple.com/motor-oil-m.html
                        I will run it about 25 hrs. but, I am sure it can go longer. It always looks clean.
                          Why is it that you think you can run longer on this brand of oil?
                          I have seen no SAE data to back up the extension of there oil change , it has no different suspension of contaminants than any other good quality oil.
                          I only recommend engine manufacturers time schedule for oil changes , in this case GM , their staff has a lot more testing hours on their engines than any one oil company.
                            Gave Beth a deposit payment today....you can beat me up when I come to pick up the parts.
                              I agree. Any idea what an new engine costs? It's not pretty and oil is CHEAP!
                              Biggest lake addict on the planet
