The hydraulic motor, or the switch, on my TAP's system apparently stuck in the up position and burnt up the motor. After spending $450 to have the motor replaced, the exact same thing happened again nine months later. Incidentally, with the TAP's on the full up position the boat will not go over 18MPH with out porpoising (bouncing up and down) so badly that you must reduce your speed to continue on, rendering my boat useless.
Has anyone else experienced the same problem and can anyone provide me with information regarding the cause. I hate to replace the motor once again, only to be in the same position I'm in now.
Is it possible that moisture is getting into the TAP's throttle switch and engaging the motor?
Rocky
Rocky
