so i get this idea that im going to lower my tower on my 2005 24v i loosen all the bolts except for the one hex head bolt on the front runner heading forward that bolt seems tight so i break off the allen wrench in it and cant get it out i try several different ways including drilling but i have no drill that can cut the back way through the bolt or front way thru the allen key piece thats stuck in the bolt any ideas???? maybe ill just never put it down but would like to get this bolt out
stupidity
Caddy, Ive been there. You are screwed. That bolt has obviously siezed. So once you get the head off you still may need to drill the threaded portion out. I ended up with a grinder with a round bit. If you are able to get the allen out try using a torx bit and a breaker bar. Mabye you will get lucky and break the head off the bolt. Good luck just be patient.
So let me understand, the head of the allen wrench sheered off in the head of of the allen bolt you are trying to remove?
If so, dont try to drill the allen, they are hardened. Instead, use that to your advantage. Take a chisel and try fracturing the broken piece of allen wrench. It may break into more pieces same as it broke the first time.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Post a pic or 2 and maybe we can come up with more ideas.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by caddy0150 View Postweld a nut where theres no way to its in a hole ...the drill is the way what kind of bit do i need i tried cobalt and titanium??
There is a tool out called a magnetic induction heating unit. OTC makes it part number 6650 It is a pricey machine though. You can use this to heat up the bolt and the fractured piece of allen wrench. Because it is magnetic you can pinpoint the heat to a specific area and you will not have flame heat so you will not burn the powder coat or anything from the tower or fiberglass. You might be able to find someone who has a machine that can help you. I have the machine and it heats the metal to a bright red. Just an idea. This will also heat up metal under or through things you do not want to heat up like fiberglass panels but the Magnetic induction will heat up any metal with in a specific range of the probe. It works great on taking out dents from cars with out damaging paint. It does not work to well on aluminum though Just stainless and regular steels.
http://www.otctools.com/products/mag...heating_systemLast edited by SPBFAN; 01-19-2010, 03:11 AM.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Originally posted by caddy0150 View Post[ATTACH]18309[/ATTACH]Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
