just want to check on the model spec it says 20v weighs 3778lbs is this with out trailer. if so what weight is factory trailer
is both over 2000kg wich is 4400lb
That weight is probably Dry Weight = No trailer, tower, fuel, and other gear and accessories. For a tandem-axle steel trailer, you're looking at 550 kg's easy.
