So I thought I would get a jump on the sun. All it is going is making me anxious!!! Got my teak all cleaned and oiled and my seats off to the upholstery shop. It put me in the mood to drop in the new system and some bags... installed the Alpine CDA-9886M head-unit and an mc-10 wireless remote above the platform, got the kicker 450.2 and my KMT6's up which I don't know if I'm going to be able to hear them after turning them up in my garage I may be deaf... My bags are coming in Monday along with 2 tsunami's looking at 1100 max in the back and 550 up front. NOW I JUST WANT IT TO BE WARM!!!!!
Waiting for the time.
sacs
Your possibilities are endless. there is not much storage space in the rear and none under my 22i. I have ordered some custom sized sacs from Fly High you give them dimensions and they will make them. they recommend you over size a sac to a compartment because then it will just conform and fill the space and you get more weight. I was able to find some that were ordered wrong that were with in an inch of the sizes I wanted and got them cheap! I ended up with 4 bags and two tsunami 1200gph for under $600. Fly High's sacks are made from the same material used to make whitewater rafts!! They assured me that there is no problem with even putting them out in the open and having people sit crawl lay or even walk on them. I mean think about a white water raft all the abuse it has to be able to handle bouncing off sharp rocks with all that force behind it. I was able to order a sac to lay in the front walkway that is around 500# I get 1 for either side of the engine compartment at 450-500# and one to put in my rear locker above the swim platform 250#. It's going to leave me enough weight to add 10 150# people and still be legal.
Originally posted by kottenmouth21 View PostI have a couple of fat sac's I fill up and they work well. I was wondering about installing I guess tanks? that would be under the floor. I'm sure its a big job and prob not worth the time.
You indicate that you have a couple of sacs already. Do you know which ones they are, i.e size, dimension or possible model #? Where do you place them? Are you happy with the wake size, shape, and cleanliness? The DD's seem to really like a 50/50 split, I would try to stay close to that or whatever you current front/back weight distribution is (unless your not happy). Before ordering either a standard or custom sac for a specific location for a plumbed in system, I recommend you get the wake dialed in.
Once the wake is dialed in, then decide where you can, and want to, stow the sacs. Then we can figure what sacs will fit the best and give you total that's as close to what gave you the best wake. After that, it's just a matter of deciding what type of pumps you want to go with and putting the plumbing together.
I cant help much with any specifics about weighting a 20i, but the rest, I be more then happy to help you with the sac, plumbing, planning and installation.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by goose69 View PostI have a 22v riders edition. I have a 1450lbs sac in each rear locker and a 225 lbs sac in the bow. I probally not legal, but I have no Capacity plate. With 10 people in the boat it puts out a massive wake.
Welcome to the site.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
