Originally posted by ImaPigDog
View Post
True on the racks, I know that Samson makes a great surf/surf rack for it but I would also like to see some type of Endless Wave rack for the top for the big boards.
I was going 11 mph in the video with taps at 6. NO weight in the front. This means if you don't wakeboard, the surf ballast system would be fine, no need for the extra weight up front. I have definitely found that the tige wants the bow high and the corner dug in and the video proves that. I was explaining this to Ben while we were out and so he said, "well lets put taps at 8" and he did. But when you do that you get excessive whitewash at the top of the wake and it starts to negatively impact the wake. You can see how this works if you remove your taps plate and your swim deck. It will create a huge rooster tail that actually splashes right into the face of the rider. At least it does that on my Ve. The deck and plate actually remove that rooster. The taps plate just needs to be slightly "engaged" and 6 seems to do that trick, yet keeps the bow high. This also emphasizes why you need a smooth underside of the deck.
Both my 24Ve and this RZ2 seem to create a good wake from 10-12 mph, adjust to preference. 12 is longer, but knocks down the wake some. 10 is a bit bigger but mushy and shorter.
Originally posted by Timmy!
View Post
I don't know about the MSRP, but I did send an email asking.
