Bought 1999 pre 2002 wt interior is trashed rest of the boat is great only 200 hrs. Can i get new skins from the factory or do i just need to go to have it all re made locally? cushions aren't to bad everything vinyl is trashed.. all thought or suggestions are welcome.
New interior needed
If the factory still has skins and the foam is reusable that would be the cheapest way to go. The foam is I the expensive part. When I took mine in the upholstery guys told me the original vinyl
had a very poor backing on it, so I went with them instead of skins from Tige. I was also lucky enough to find a good match as I did not need a complete redo.
Vault? What have you found for the best vinyl?
I'm replacing the rear seats on my 2300V. So far, I've found that Colorguard 2000 Boltaflex is excellent quality. 36oz weight which is superior to 2010 OEM boats. Not cheap at $20/yard but you pay for quality.
I'm looking for alternatives so let me know what you may have found out.
