I damaged the prop on my 22i beyond repair and am considering replacing it with other than the factory issue prop. My 2005 22i came with a 515 13x12 VL 1 1/8 (a friend of mine has a 2008 22i that came with a 525 13x11.5 VL 1 1/8). Both boats have 5.7 Vortecs, but his boat shipped w/factory ballast, which may be why his prop diameter is different than mine(?). My boat isn't drivable at present, so I can't advise on Wide Open Throttle RPM.
We load both 22i's with approximately 900 lbs for wakeboarding, and approximately 1,800 for surfing (port side). Wake/wave shape and size are very good and hole shot is not a problem with the current props, however, could we get a better surf wave without too much of a drop in fuel economy with a different pitch/size propeller? Any input is appreciated.
Thanks, T*
Thanks, T*
