it was about 2 years ago when i almost bought a 22v after the 20v i tested was sold, but my FJ wasn't able to tow it so i decided to wait on the purchase. luckily, that was a great decision based on how the economy turned out. i have since moved into a new house which is on a corner and i have the opportunity to redo some exterior walls to make room for boat storage on my side yard. can anyone help with how wide i should make sure the inside dimension is? i am not worried about the length, but not having a boat in hand i am unsure about the width. i would like to be able to buy a 22v within the next year or two or if a good deal comes up on a used rz2 than pick up one of those.
side yard boat storage
I have a 10' gravel pad with an 11.5 wide gate opening.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
for some reason i was thinking more was needed i have room for about 20' outside dimension which will give me about 18' clear inside. i guess i can make it smaller and create a larger court yard for the front. that's actually some really good news since it should cut down my budget and save a little money.X
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
we have about 6" on each side plus our driveway is up hill with a curve to the right. what a painPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Originally posted by jake's02-22i View PostNow that i think about it you should make it about the size an RV is because if you ever sell the house you could gain a bigger market with RV/Boat storage.X
