We have discussed anchors. I posted a pic in another thread that brought out the question of how I anchor.
Anchor System.jpg Rough sketch
I usually take the first 15 minutes taking time to set up my system when I get to the lake. It takes a few minutes, but has been solid over the years. I have a 30' anchor rope that I tie to a sand spike on the beach, with a loop on the end that I have to slip over my rear cleat, then I tie on my 100' anchor rope and another loop placed to fit the front cleat with a bouy hooked to it. I then set the anchor (Large box acnhor) attached to the other end of the 100' rope on the swim deck and drive out until it drops in. I then return to the bouy and set the anchor by attaching the furthest loop from the beach to the front cleat and driving to the beach until the anchor sets. The box anchor usual sets the first time and quickly (fluted anchor didn't set as well) Then I pull the slack out of the 30 line tied to the sand spike. This generally leaves the back of the boat in a few feet of water when you have the boat facing bow out. I make sure that when the long line is strecthed I will not bottom out. I then am set for while I am there. When people board the boat they have to get wet usually only to the knee, but cleans feet. When I return I just hook a turn into the bouy, grab it attach it to the front cleat and pull the rope to the rear cleat.
The pictures above show the system.
I also have an anchor buddy that allows you to float the boat further off shore. I use the anchor buddy generally when I am tied with the small anchor rope off the corner of the house boat. I tie off the corner opposite the slide and then the boat free floats off the back out 15 to 20 feet off the back of the house boat. I really like my boat away from other stuff and these systems allow it to get close, but not hit anything.
This system has held up in 60 mph winds. My wife just tells people when I arrive to be patient I just have to do my anchor thing and then we'll be ready to play. Usually I play between launching and anchoring, so this doesn't interfere with my fun.
Share you ideas and how you do your thing.
