RZ2 rear storage
    RZ2 rear storage
    Does anyone know if you should put a fatsac in the rear lockers. It says not to step in there so i was wondering if it could handle a 540 lb or 750 lb sac?
    yeah you can put them in there. I wouldnt leave full permanently. You can confirm w/all the rz2 guys on here on what they are running back there weight wise
      no problem
      Guys are running the 800's in each locker.
      I did Coach's ballast system and he is running the 600+ in each rear locker.
        I have a 1000lb in each of the rear lockers of an RZ2. I did reinforce the brace for the inner firewall.
          I added 450#'s in each rear locker with no additional bracing or issues. I had the same question and had my dealer check with Tige. They said it was fine.
