Ok, if you want a simply easy solution here you go.
1) bring an extra battery and just use it for jumping only.
2) hook three batteries up using the same perko switch? run two of them in parallel on switch one, and the other one on switch 2. Only use switch 1 except when you need to jump and put it on switch 2 to start then move it back to 1 to charge. pull the one you use to jump out once a month to charge it with a battery charger.
Thats about the easiest way to be deat battery free.
Dom
Dom
