i have a 2005 24v riders edition with the 6.0L engine . the engine has the pink radiator fluid is there anything else cooling this engine if so where does it come in and how far should the tank be full (res) what is the fluid is it dexcool?
cooling system
Should just be Dexcool. That engine has a heat exchanger that is cooled by lake water in which the Dex circulates through. After the raw water passes through the heat exchanger, it goes to the manifolds to cool them and then out the exhaust.
Check with the engine manf, some recommend an additive for the alum blocks, but typically not needed when just topping off a little.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
