ACME 1235 Discount for August Only
    Guys, I know this is on the heals of CHP group buy but I just got approval to sell the 1235 for $450.00 plus what ever frieght is until the end of August. I don't want to crush what CHP is doing at all but also don't want to pass up this opportunity it is only good until the end of August 2009. I have found freight to be about $15.00 on most cases once it was as high as $20.00 to the other side of the country.
    argh. Just bought one.
      Duncan- how different is the new prop from the stock prop?
      I might want one.
      Tige owner since 2006
        I might want one.
        My 1235 seems to hold speed and handle better while surfing with 1000lbs of ballast.
          I might want one.
          When I put this prop on my boat it stood up out of the water. I have the 6.0L and my hole shot was terrible until this prop came around. I lost about 4 mph on the top end but I did not need to go 43 MPH anyways. 39 MPH is fine.
            You'll notice a huge difference in the low end. Amazing for surfing. Our lake is usually choppy so I can't go fast enough to see what we lost off the top end.
              Ok, I have had several inquiry's on this prop. Email me if you are wanting one so I can get your invoiced out to you. andrew@automarinecare.com.
                Can you incorporate a 1237 with this buy??
                Had the 1235 but my 6.0L will perform better with the 1237.
