contact info (muffler shroud)
    I have a 2005 22v and apparently it had a fiberglass cut-out (probably a drill scrap) left in the exhaust (most likely during manufacturing). Well this got lodged in the exhaust and blocked all h2o and air from escaping on the starboard side causing the engine to over heat. The exhaust shroud failed causing fiberglass to come out of the exhaust.
    I need to get this new part ASAP, any one have any contact info direct to tige? I had to replace a seat cushion a year back and tried to go through tailors boats for 3 months, with no luck. I finally got a hold of a guy in the factory who sent it out the next day! Tige really stepped up and got it out ASAP.
    Also what are the chances of getting this covered because this is clearly a assembly problem...
    freedom recreation rentals
    www.boatutah.com
