Speaker shop - Houston, TX
    Anyone know where I can get the Kicker speakers fixed on my boat?
    I am new to in Cypress, TX. That is in the Houston area.
    I have been looking on-line today and Kicker dealers are in short supply.
    I have 1 tower speaker that has no sound.
    I have tested them by swapping them. One works one doesn’t
    PM philsailz, he supports Kicker products and should be able to tell you.
      So, did the dead speaker can work when you swapped speakers and the original dead speaker stayed "dead" when moved to another can?
      If the known-good speaker worked where the original didnt, you need a speaker, if the known-good didnt work when wired up to the original "dead" one, then its a wire or amp problem.
      Gives us some more info such as answers to the above questions, how many speakers you have and what model amp you have powering them and we can help get you fixed up.
        X2
          Thanks for the replies.
          I am looking for some pictures. It seems all the pictures I take in my boat are below the tower... I will post something soon
          Riding on the water with one speaker this week end was painful
          They are factory Kicker/Tige set-up with the tweeter attached to the speaker can. 3 speakers on the tower with a twist lock connection on the can.
          The dead can did not work in ether location.
          The tweeter did but not the speaker.
          The good can worked in both locations.
          I was not sure if it was the speaker or the board in the can.
          I cannot find a Kicker dealer around Houston
            Pictures
            Here is the only shot I could find with my tower in it.
            http://www.tigeowners.com/forum/pict...&pictureid=312
              call brandon or steve at Texas Tige... they can fix you up for sure
              www.texastige.com
              (936) 447-8443
              they are located right off of 105 across from lake conroe damm.. about 30 min from ya
                Thanks
                  WRASCO,
                  Give me a call at the dealership tomorrow. I have an extra set of Kicker tower speakers in stock I will make you a deal on.
                  Thanks,
                  Steve Parkin
                  Texas Tige Sales
                  936-447-8443
                  sales@texastige.com
                    www.texastige.com
                    (936) 447-8443
                    30 minutes from Cypress?
                    If its not fun, Why do it?
