A couple of things to point out. Pressure, measured in pounds per square inch, is a result of force and resistance. If you have no resistance, you have pressure. The sacs are bulging, thus applying unwanted force on the boat, because they are not vented.
So, if I'm understanding Ragboy's dilemma correctly, he needs the sac to bulge in order to get as much weight out of it as possible, and this is done by using a spring loaded c/v. But the bulging and pressure is now reeking havoc on the boat. Kinda a catch-22, huh.
Well, I hate to say it, but I gotta go back to my original suggestion of going with the original Enzo sac. Because the sac is larger then the storage area, it will fill almost every in. of the storage area, giving the maximum weight possible. When vented, the sac will not build pressure and bulge, thus no undue stress on the boat, but will fill as full as the storage area will allow. Kinda like putting a 55gal trash bag in a 30 gal trash can, it still holds 30 gals, but the sac will fill the entire can and not leave any voids. No added stress to the can, unless you overfill the can and then try to force the top down compressing the trash
