So, many of you guys have been asking about our ballast in our boat. Its fairly simple, and I did a How To Wakesurf 101 video on it, take a look:
So basically, 2 enzo sacs from fly high and 2 jabsco pumps, each with their own inlet from the bottom. Empty back out the bottom.
There are several issues we are working out.
Those are the main issues. We are working on solutions for all of these things. And eventually plan on having a kit, and perform local installations in our bays. About bulge. Stuffing them in under the side seats, because you can't have a 3rd rectangle cut in the shape, is def an issue over time. I have put about 70 hours of CONSTANT use on this system, and cup holders are starting to pop out, firewalls in back knocked out, which isn't so big a deal, and fiberglass is being stressed. So I pulled all the sacs out, and put on the ground in the LAB and filled them up.
This one looks like one sac (drivers) is much smaller, but its an illusion, only about 16 inches shorter.
These things bulge on the sides, as much as 5 inches out on each side, making the bag 10 inches wider than measurements. Bulge factor is huge, and its a lot of pressure.
Here is a great picture of the bulge, this thing bulges up, about 6 inches taller than ordered dimension.
Here is the front area where they are stuffed in. You can see how they will put a lot of pressure in here, not designed for it. And when we fill up, which we need to fill all the way up to get the wake we do, the seat bulges up. And when you let off throttle, the water rolls up the side of the boat, and pushes you up out of your seat.
We have methods for dealing with all of this, I would say we won't be done until the end of the season. Ready for off season upgrades.
Hope that helps.
- The sacs shift a lot
- The sacs bulge way over size
- due to bulging, its destroying our boat
- tough to tell when empty, melt impeller
Hope that helps.
