My New RZ2
    Originally posted by lincdarrow View Post
    why only yhe underwater light and exhaust on 1 side??
    The PCM engines on the 2009 models only have one exhaust.
    As far as the lights, the factory will probably put as many lights on as there is space...if you want to spend the $$$ for it.
      Its one of Tige's cutbacks this year.
      Common Sense is not so Common
        And the other possibilities for only having one exhaust port:
        Quick! Take it back to the dealer, they forgot one of your exhausts! Make them put it in while it's still under warranty!
        So its cheaper to replace the muffler bearings.
        It is almost as good as an FAE. Half the exhaust ports = half the exhaust volume.
        The 2nd one is an option. Mastercraft's new "superbling" model has four exhausts. Why did Tige go cheap?
        Due to the economy, Tige has placed the man who drills the second hole on seasonal layoff.
        The two exhaust ports were causing the TAPS to fail due to massive exhaust pressure.
        Half the exhaust ports = half the carbon monoxide exposure, half the greenhouse gas emissions, and half the carbon footprint. Part of becoming a greener industry.
        They discovered that the dual ports were causing a harmonic resonance that interferred with the music coming from tower speakers. Therefore, the rider could barely hear the music. This is a revolutionary change that allows the full sound waves to reach the rider without the noise cancelling effect of the dual exhausts.
        It counteracts the torque of the prop giving you a more balanced ride.
        Exhaust flaps are in short supply.
        Because its a hybrid.
        It was supposed to have 2 exhaust ports. After looking inside the boat, we discovered that the second exhaust line is hooked up directly to the blower vent.
        The 2nd exhaust port supplies hot air to the heater.
        And the #1 reason for only one exhaust port...because Chuck Norris said so.
        Thank you, ladies and gentlemen. Please remember to tip your server. Sorry, Guapo, for the Not trying to make fun of lincdarrow for asking his question, just trying to have a little fun.
          BTW, this engine's exhaust is really quiet.
            now its super easy to make ur own FAE lol.
            Being a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
