RQST- This asks the ECM permission to take control
STAT- This wire signals to Perfect Pass that it has control ( This is also the beep)
VGOV- Is the wire that tells the ECM the needed RPMs
Those are the only 3 components that Perfect Pass uses to control the engine. So as long as they are accessible, and they probably are because Marine Power uses the same MEFI ECMs as Indmar.
Common Sense is not so Common
Oh, do they, now oh smart one
