Adding ballast bags in a 96 22v
What are the largest bags I can use in a four bag system, one on each side of the engine and two in the front under the seats? I plan to use a reversible jabsco pump, and a four way manifold with individual shut-off valves. Can the pump be tapped into the engine water intake(Fill and discharge), or should this tap into a seperate thru-hull fitting?
To exceed 1200-1400lbs, would I need a fifth bag in the front center isle(600lbs more or less)
