I just got my shipment from Andrew to install my ballast system. Thanks Andrew! Great prices and lots of help. Looking to install it this weekend and going to pick up the parts tonight. I've been briefing myself on Nharp's, Coach's, and G-Moneys install threads. Any other good ones? In Eks thread, none of the pics are showing.
I have an 08 Z1. Going with nautique wedges in the rear lockers and an integrated bow sac. I know it won't fill all the way, but I'd be happy with 300#+. 3 Ballast puppies. Then two fat bricks and a manual tsunami pump for the bow as well.
I haven't looked yet but I'm hoping to fit two of the pumps behind the access panel in the rear locker
* Any recommendations on tubing, willing to pay more if its worth it. I like the tubing in Coach's install, the flex PVC and multiflex tubing. Looks like it worked out well for him. Anyone know if he had to put any 90s in when running the flex PVC?
Anyone know if this is sold locally like at a Home Depot?
* Front Bow Sac: Is it necessary to fill from both ends on the bow sac?
* Scoop grate assembly for the manifold, is this purchased locally and is it the best way to go for this component?
* I keep reading about all the check valves not sure which way to go. Seems like Coach's install was the simple and just had the one on the vent to keep air out. But I don't know what problems he may have had with draining. If adding all the check valves just keeps you from having to top off every once in a while, then I wouldn't think its worth adding more seals to the system. Anyone know how much water is actually lost or if they self fill while driving?
* Is it best to drain/fill from the bottom or top of the sac? I would lean towards the bottom but have read some say top to help with the self draining.
* Any other suggestions would be greaty appreciated
Thanks!
Thanks!
