I am pretty sure my ballast system is syphoning the water out or leaking back through the fill line. The system has been in the boat for several years and working fine, but last weekend the port bag kept emptying out and appears to be going out the fill line. Could the check valve gone bad? Also, it looks like my vent line was crimped, so it was actually pushing the excess out the drain instead of the overflow (it is t'd into the fill line). could the overflow being crimped cause the check valvel to jam?
Lee, do you remember where the check valve is in this boat? Do I have to pull up the section under the seats to get to the vavler?
Thanks
Thanks
