Finally got got some time to clean up the install, re-route some hoses, and finish taking a few pics.
Just going to hit the highlights as there a handful of very well detailed installs already posted.
Front: Integrated Bow sac = 500#'s
Starboard Rr: V-drive sac = 400#'s
Port Rr: "L" shaped Surf sac = 700#'s
7 Attwood T800 Tsunami pumps:
3 fill pumps on PVC manifold feed by 1.5" thru-hull mushroom
4 drain pumps (1 for ea rear sac and 1 in each leg of the bow sac)
3/4 hose and fittings
Vents and drains on each sac are T'd together to cut down on holes in boat
Stern drain pumps located behind bulkhead wall.
I added all new valves to the surf sac because the factory ones just didnt work well
didnt fill all the way, didnt vent, and would not drain fully.
Fill and vent
Drain
Starboard drain pump
400# sac vent
400# sac fill
Port drain pump
Switches
Manifold and pickup
Hose routing, fill
Fill and vent
Drain
400# sac vent
400# sac fill
Port drain pump
Switches
Manifold and pickup
Hose routing, fill
