ballast problem solved
    I test surfed a 24ft centurian enzo and let me tell you, these guys have it figured out. you can't believe the wake we had. for sale 07 24ve.
    Ask not! what your wake can do for you, ask! what can you do on your wake!
    Crap, another 24Ve for sale.. That's all I need.
    You might want to talk with Ragboy about he dialing of a surfwake on a 24Ve. Ragboy is under the assumption that his boat can produce a better surfwake then the Centurian. I would have to agree with Rag on this.
      toss the enzo sac in your 24Vé and you'll have a ridiculously nice surfwake IMHO.
      If you ain't falling.. you ain't trying hard enough..
        I have tried alot of different things but have not even come close to that wake.
        It wasn't just the size but also the shape and the length that impressed me. The shape of the bow also does not allow water in the boat like my tige.
          Also Greg Mallock (sp?) has his 24V dialed in with that Enzo sac also.
            enzo is the model name for the centurian boat.
              And also the fly high sac that goes in the enzo....
                Originally posted by Timmy! View Post
                I don't know about that, but the boat I tested had hard ballasts.
                  From what Ive heard, surfing is all it's good for. Good luck.
                    Yes, Fly Hi has their "Enzo" sac for surfing, but the Centurian Enzo does not use it, but uses hard tanks that permanently take up what little storage the narrow/shallow stern of the boat has.
                      From thread http://www.tigeowners.com/forum/showthread.php?t=7705
                      We range from 190 to 240 pounds. We have tried all speeds from 9.8 to 11.5 mph we ride the 6.0 ft hyperlite and a smaller board [can't remember the make ] We have been putting 400 pounds of water in each locker and then sitting everyone in the boat on the side of the rider. taps set at 4 I am 190 lbs and I feel a lot of push but not enough to throw the rope. Do I need more weight? do I need to put all the weight on the rider side and keep draining and filling to accomodate goofy foots?
                      Simply put........yes, about 1400#'s on the surf side alone based on what other 24V/Ve owners have posted.
                        WHY
                          WHY
                          I've read comments on poor wakeboard wake, lack of storage (confirmed myself), lack of comfortable seating (again, confirmed IMO) rough ride.
                            Here are some comments on WW about the Tige and Enzo.
                            http://www.wakeworld.com/MB/Discus/m...21/381082.html
                              Good to know. thank you. I know that when all my sacs are full there is more storage on the centurian than on my tige. The rough ride I didn't notice. I don't wake board anymore so I don't know about that. Did you surf the centurian? I think tige should start building their boats with auto ballasts and quit doing so much bragging about the way over rated taps system.
