Fly High V drive fat sacs
    I know some of you must be using these sacs, have you been happy? Do they have a separate drain and fill opening? Any help is appreciated!
    I really like mine. In fact, that's what I used for my automatic ballast system. They are very sturdy.
      Awesome. I used them for my automated ballast system as well.
      Durable and tough. Fit nicely in my rear lockers as well.
      Be excellent to one another.
        I have them, and they work great
        They have one vent on the bottom and two on top.
          I have them too! They are very heavy duty! I also have a pair of "Masterline" sacs, not even in the ballpark with the quality of the Fly High's.
            Got 4 of them, Fly-High all the way
              If you decide to get the Fly-High V-Drive sacs I have a set of used ones you might be interested in, $100 + shipping. They were used 1 season(last year) and in great condition. They were perfect for wakeboarding but I bought the bigger Fly-High Fat Sac (750lbs) this year for a better surf wake, I just don't fill them full when we wakeboard. As advised by Fly-High I did glue in the quick disconnect fittings, but I have removed them per the Fly-High recommend procedure. There is some residue from the glue, but no damage what so ever. I'm gonna be out of town till Thursday afternoon, but when I get home I'll post some pictures so you can see what I'm talking about.
                What type of glue did you use?
                  PVC, it's what Fly-High recommends. The fittings were removed by heating the fitting with a hair dryer before removing, no damage but it does leave some of the PVC residue.
                    Thanks for all the input, guys! If this goes well, I hope to plumb them into an automatic system as well.
                    BlownC6's response makes me want to ask...do I need these quick disconnects he speaks of? Please forgive my newb-ness!
                      Weil,
                      The quick con's just make it real easy to remove the sacs for cleaning/drying of the boat. Either way, you still will need to buy a barbed fitting for the sacs when you plumb it in.
                        I use 3M 4200, the PVC glue did not hold tight and long enough. Next ones will probably get 5200.
                          And you're still using the quick release fittings?
                            Thanks chp. And thanks Blown, I'm interested, and look forward to seeing the pics.
                              Just buy them, $100 is a deal!
