I just purchased a new 07 24ve and I love it but it had no ballast installed in it. I have been doing the bag thing but it is getting old fast. I have read most of the ballast install threads and have decided to get one put in. (1)This is the system I’m going with and would like any suggestions from anyone if they have a similar system and wish they would have done anything different. I will not be installing it as I will have it done by my dealer, but they are very good to do as I ask them, so let me know your thoughts.
Rival System but instead of the rear bags I will use Enzo Sacs on both sides. (2)With the enzo sacs will I need bigger pumps or will the ones in the rival system be okay?
(3)Should I get the pro x series integrated bow sac, also instead of the ones that comes with the Rival System? It gives more weight 650# vs. 400# but I have read you can’t fill it all the way? (4)Any thoughts or suggestions? Plus I guess in the Rival system there are 2 separate bags so this means more control but also means more pumps and fittings. (5)Is it best just to have the front weight on one side when surfing or do you think the one bag is okay?
I also read something about switch placement but now I can’t find it. One person said they always hit their knee on it but I don’t remember where those switches were located. I see where one person put it under the speed set controls and some boats I have seen have it on the side in front of the throttle. (6)Which is better?
(7)How do you tell how full your sacs are? Do you look in the compartments and watch them fill? Do you just know by time? (8)If you want equal wait on both sides do you turn both pumps on and off at the same time?
(9)Did you have to move your battery shut off switch and if so where did you move it? Mine is in the back compartment at the bottom on the passenger’s side of the boat, so the enzo sac will be sitting on it.
I know I have asked many different questions, but I know there is a lot of knowledge out here so I would appreciate any answers you have and any thoughts or suggestions. This is going to cost a lot and I only want to have to do it one time and I want to make sure I get it done right with no regrets. Thanks for your time.
