I would definitely use a single inlet with either the Jabsco or the Johnson pumps along with a PVC manifold. You then only have one penetration and one shut off. I prefer the Johnson pump. My experience is that they are faster than the Jabsco and a lot faster than the tsunami pumps.
2002 22ir ballasts
Originally posted by jake's02-22i View Postnice. how close do you think i can drill the holes in the bottom of the boat because i want to be able to access the shut off valves all together.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dejoeco View Post. I prefer the Johnson pump. My experience is that they are faster than the Jabsco and a lot faster than the tsunami pumps.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The Johnson pumps are rated for 12 gpm. (189-102469003 ULTRA BALLAST PUMP) I have had both the Jabsco and the Johnson and the Johnson fill faster period. I don't care what the specs say. As for the tsunami pump, it is a lot slower. When I am wakesurfing and I am changing up sides for friends who surf goofy, it takes several more minutes to empty one side (using the tsunami) and fill the other.(using the Johnson)
There is an access panel right behind my engine cover in the 22ir I was thinking about putting all three thru hulls right there with a 90 degree on the thru hulls, the shutoff valves and then the Attwood pumps 800 or 1200 depending if I can find all the fittings or not the pumps will be below the water line laying flat.
Do you think that I might get air stuck in-between the 90 and the pump?
Originally posted by jake's02-22i View Postjohnson pump is a nice pump 12gph and 189.98 at boatfix.com 102469003Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by jake's02-22i View PostThere is an access panel right behind my engine cover in the 22ir I was thinking about putting all three thru hulls right there with a 90 degree on the thru hulls, the shutoff valves and then the Attwood pumps 800 or 1200 depending if I can find all the fittings or not the pumps will be below the water line laying flat.
Here is a quick illustration showing option A with a single thru-hull and a 90* elbow. This should get the pumps down below the water line and prevent vapor-lock. Option B has the pumps in line with the thru-hull. With the added length of a shut-off valve, i'd bet thy will be prone to vapor-lock.
Just some thought that come to mind.Attached FilesLast edited by chpthril; 09-24-2008, 07:58 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
My thought hull fitting is located on the port side of the engine compartment at the rear of the compartment. There is an elbow going to the stern and the shut off is accessible in the rear access compartment. I then turned 90 degrees and made PVC manifold with three fill points; one each for the rear lockers and one going forward for the front sac.
chpthril i was thinking of haveing the pumps lay longways with the boat with the 90 and no check valve because im going to run the hose high up and then back down to the bag. if i use the johnson pump i will pump the pumps in the compartment and not put them as high so that it will not have a problem primeing e
Originally posted by jake's02-22i View Postchpthril i was thinking of haveing the pumps lay longways with the boat with the 90 and no check valve because im going to run the hose high up and then back down to the bag. if i use the johnson pump i will pump the pumps in the compartment and not put them as high so that it will not have a problem primeing eMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
