I have a ballast puppy to two port locker fly highs stacked on top of each other which completely fills the locker. I'll also put two people in the port side of the bow also along with people sitting in the back corner. With the taps on 3.5 and 11.5 mph it sets up a really nice surf wake. I'm also running a four blade prop so your speed might differ.
2002 22ir ballasts
Originally posted by rogersbm82 View PostThe cheapest way is use my way. We use The large coolers, fill them with water with buckets. Works like a charm!Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by hubdawg View PostI have a ballast puppy to two port locker fly highs stacked on top of each other which completely fills the locker. I'll also put two people in the port side of the bow also along with people sitting in the back corner. With the taps on 3.5 and 11.5 mph it sets up a really nice surf wake. I'm also running a four blade prop so your speed might differ.
I have this exact boat and have done a lot to make the boat as easy to function as possible. First of all I ended up ordering custom sacs for the two rear lockes from Fly High. The weight is approx 400lbs each. I also have the bow sac and I like mentioned above, it does not fill up 100%. If I were just wakeboarding I would not buy the custom sacs. I wakesurf more and really want as much as I can get.
Now for the pumps, I put DPDT switches on the dash. The up is to fill and the down is to empty. I have used the Jabsco BAllast puppy, but did not like them because of too many issues with the impellars. I switched to a Johnson ballast pump that fills the custom sacs in less than 4 minutes...sweet. I use these pumps for fill only although they are reversible. I added the tsunami pumps to empty and placed them at the bottom in order to self prime. If you use the tsunami pumps to fill, you need to prevent the water from being forced through the pump and filling the sacs when it is unwanted. I cut a hole in the hull and installed a thru hull strainer with a shut off and then to a PVC hub that feeds the three different sacs.
I would not put three mushroom intakes just because i don't want three holes in my boat. One is plenty as far as I am concerned . I can't remember, I either have an 1.25 or 1.5 inlet that goes to a shut off and then to some PVC pipe that I made into three distribution points for the three pumps.
Originally posted by jake's02-22i View PostIf I used three mushroom thru hulls on the bottom for the three fill pumps and kept the pumps close to the bottom of the boat then arced the multiflex pipe really high and then into the sacs do you think that would prevent them from draining and filling?
The best advise is to plan, plan, plan, and plan some more. Try to envision how it will go together when installed. You will have less speed bumps and oh crap's, when you get started. Remember, when you start drilling holes, you're kinda committedTake pics and keeps us updated
Originally posted by jake's02-22i View Postusing all attwood 1200 tsunami pumps woud you go 1 1/8" thru hulls or just keep it 1"
same with tube 1 1/8" or 1"
IMO, the Tsunami T800's are much easier to work with and will have far less connections that are potential leaks.
Pro's: 3/4 NST are easy to find fittings/adapters for. 1" hose will slide over the threaded inlet and outlet of the pump and Fly High offers 1" fittings for their sacs.
Because the threaded fitting in the sac is the common restriction on any ballast system, the fill rate between the 800gph and the 1200 gph pumps is not that great.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The tsunami pumps will need something to prevent the water from filling the sacs when unwanted. That is one reason I used the Johnson pumps are a balst puppy from Jabsco.
My boat came with a stainless steel 4 blade 13 x 13.5 prop. This did not work very well for wakeboarding with a lot of ballast. I have changed to a 3 blade 13 x 11.5.
Originally posted by dejoeco View PostThe tsunami pumps will need something to prevent the water from filling the sacs when unwanted. That is one reason I used the Johnson pumps are a balst puppy from Jabsco.
My boat came with a stainless steel 4 blade 13 x 13.5 prop. This did not work very well for wakeboarding with a lot of ballast. I have changed to a 3 blade 13 x 11.5.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by jake's02-22i View Postnice. how close do you think i can drill the holes in the bottom of the boat because i want to be able to access the shut off valves all together.In this case, impeller type pumps (Jabsco's) would be your best bet, or use a single inlet and a pvc manifold.
