Are you doing the front and back or just back? I will be following your posts closely, after filling 4 bags manually last night it's definitely time to integrate the rear bags for me. What do you think it would cost to just do the rear bags? $150? $200?
I am doing the front and back. High Fly U upfront and the Rear seat bags in the back. Should total out at about 2050 lbs totally full. Plus I am going to add some extra lines so I can add another 200-300 lbs bag to one side or the other for surfing. After seeing Big Waves wake with the full ballast full and the extra weight on one side I want that! Just the rear bags will be around $300+ Talk to SPBFAN (Andrew) about what he can get those bag to you for. Those bags are 700 lbs each and only go up 10" so you still have your rear locker space.
Winston Churchill
I need to learn to read. I can stay SPBFAN will get you a good price on the pumps and the whole system. PM him for more details
Winston Churchill
another ballast boy is joining the ranks. You doing this out at the river ?
NO! Way to hot. I am going to get my boat tomorrow and going to Bluewater in Parker until Tue. I am bringing the boat home for the annual service and should start the project Friday morning next week. I hope to be done Saturday night so I can take it to Elanor Sunday to Lake test it. The the first trip is a week up at Lake San Antonio!
Winston Churchill
The parts are starting to roll on in! I am getting pumped up about doing this!!!! Next weekend the fun begins
Have you thought about 2 separate bags for the front? It's been about a year since I was in an rz2 with the u bag, but I didn't think it was a real good fit because the bag was actually an "A" shape. Has this changed?
You could put some Pop bags in the very front, between the 2 bags.
It's still is more of an A shape bit it works perfect in the RZ. in fact the RZ models are the boat you can fill the bag 100% plus he will still have room fore storage.
Coach, I would be carful with that hose. It is so thick it is hard to get clamps that clamp it tight enough to seal it up aroud the barb connectors. You should get what is called T-Clamps if you are going to use that stuff. They will clamp down real tight on it.
I asked EKS and he said he didn't have any problems with it. I am only using it from the Manifold to the Pumps. If it is a problem I will see if I can find the T-Clamps.
Winston Churchill
