Nice job Dogebert call me on the impellers.
Automatic Ballast for a 2100v Ltd
Originally posted by SPBFAN View PostNice job Dogebert call me on the impellers.
Thanks again for getting me motivated to do this myself!Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
I tried this and was not happy with it. I had issues with air getting in the water intake to my impeller. It caused my temp gauge to do weird things.
You're better off doing what I did. It's really not that hard and you have plenty of room back there. You will need a buddy to help, tho.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by jwanck11 View PostWow. Cool! How long did the project take??www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
All-in-all, it probably took me twice as long as it should have, but I was being anal about having all the right stuff on hand. Way too many trips to Home Depot and the aborted raw-water intake option.
I would say you could get it all done in a weekend pretty easily. There's a fair amount of dry time for the thru hulls. I used the fast drying 3M 5200 adhesive, but it still takes 24-48 hrs to cure. If you have a helper, it goes much faster. The installation of the fittings was relatively easy, it took longer to wire everything and run all the hoses.
My situation was somewhat unique because my boat couldn't handle the 2" intake SPBFAN and others have used, there just wasn't room for it anywhere.That reminds me, I have a 2" thru hull, scoop and shut-off valve that I never used if anyone needs one. These parts are kinda expensive, so I'll just include the shipping to wherever you are in the price.
The vents were easy to install and didn't take a lot of thought. The bigger dilemma for me was the intake. The idea for the 1" intakes came from my son Ryan. SPBFAN validated that it would work when he told me that Mastercraft used the Ballast Puppies in their boats and had individual intakes in the bottom of their hulls.
The system is really nice and I've not experienced the leakage the others reported...perhaps because there's no vacuum created at the transom like there would be with the scoop. It fills and empties really fast and I can dump ballast while underway. I do have to be either in lock forward or idle to fill, but that's not a big issue.
As for the other issues mentioned in other threads about not knowing when you're empty, it's pretty easy to tell by the bubbles coming up from the transom when I'm just floating.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert View PostI used the fast drying 3M 5200 adhesive, but it still takes 24-48 hrs to cure. .Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Originally posted by Coach View PostDid you use he 5200 on the vent though hulls as well or just a silicon sealant?Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert View PostYes. I suppose silicone would have been enough, but my rear vents are often bellow the waterline when we're surfing as we have water flowing over the rubrailSuccess is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
