Currently planning to upgrade from a 20V to the 07 24ve. Not that there hasn't been any discussions regarding the 24's and their wake, but will a ballast or sacs be a necessity to produce a generous surf wake? I have a 750# Fly High that I can add to a compartment but taking the storage space is not preferred. Thank you.
24Ve Ballast Needs
HunterD, welcome to the site. As bentone has mentioned, it will take a lot of weight to list that beast. bentone has a very good wake but every boat will have a different setup. Just be patient and you will get it.
Have you bought the 07 24Ve yet? Doesn't sound like you have but when you do, post some pictures so we can all see.
Welcom to the site and congrats on the upgrade,
The Enzo sac seems to be a good fit, and the right amount of weight in a 24V/Ve for a sweet surf wake. I've been lucky enough to have surfed behind both Talltigeguy's and Xpjim's 24V's and the wake is greatMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
More room
Smoother ride in bad waterPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
How big is your crew?? The 24 just has a lot of space, seats 8 easily, while 8 in the 22 can be a little crowded. I would go with the 340HP in both, so no difference there. The 22 will take less ballast to get a good wake. It's 2 footitis though, you get the 22 and say man, I wish I had the 24.....at least that's what they say. You are going thru the same upgrade as we did. We had an 04 Switch V (basically 20V) and went to an 06 24ve. The wake of the 20v in my opinion stinks. We loaded our 20V with over 2000lbs and I thought the wake was marginal at best. We have the same amount in the 24ve (2000lbs) and the wake is great. The 24 doesn't porpose at all like our Switch V did.
I have also ridden behind the 22ve, great wake, pretty much identical to the 24ve wakeboard wake. You can get a killer surf wake from the 24ve. Good luck with your decision.
come on guys, that was cheapOriginally posted by bentone View Postcheck out this thread, special ballast.. http://www.tigeowners.com/forum/show...ht=powell+pics
I just down sized and would agree that the rz2 was a little bit bumpier in the water than the 24Ve. But again, I wouldn't bet money on that either... The conditions that I have taken the 24Ve in and so far the RZ2 do not compare... However, I was in 2 foot swells with the 24Ve while today's outing was only 6 inches.
