If I am going to be using the t800's for draining, do I use 3/4" hose to a 3/4' thru-hull?
Thru hull size?
Originally posted by rushin View PostIf I am going to be using the t800's for draining, do I use 3/4" hose to a 3/4' thru-hull?
If you haven't bought your hose yet, consider using 1". It will slide over the threaded end of the T800 so no need for a 3/4 threaded fitting on the end of the pump. The you would use a 1" thru-hull.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by rushin View PostI have not bought anything yet but I am ready to. And my plan is to use the t800 for draining.
So I get a 1" thru hull and 1" hose and I should be set?
Where is a good place to get hose?
If xp dont chime in, I'll get it tomorrow for you.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
