My Rival system has been awesome except for the gate valve failure well published on the Rival install thread.
At Lake Mead Last week, I was filling up both rear sacks getting ready to surf. I heard water coming out the starboard side so I knew it was full. I shut off the pump to that side, but the water just kept coming. I thought that was strange. Much to my surprise, the water was coming out the bilge hose, not the ballast overflow
. I check in the engine compartment and there is about 6 inches of water!
Water can be seen oozing from the starboard storage compartment into the bilge. I dig into the compartment, removing the water weenie and other tube that sit on top of the V-drive side sack, and the side sack is nearly full, but water is pouring out of the ballast pump that has broken.
Check this out!
Check this out!
