Ballast For a 24ve
    Ballast For a 24ve
    We're looking at an 07 24ve we have a 20v now wakes just too small. Anyone know of a automatic ballast system that offers 2500 to 3000 pounds for a 24ve?
    Thats a lot of ballast. The only chance for that I know, for automatic, is Rival Industries. Their website is down, but they are basically just a Tige dealer in AZ. Someone else here probably knows the number.
    http://wake9.com/
      I think you can buy the hardware from Rival and then choose your own sacs. If you are feelin frisky, do your own custom install. Xpjim just did his, CP3 and I are both working on on our own sytems.
      Rival install http://www.tigeowners.com/forum/showthread.php?t=2140
      custon install http://www.tigeowners.com/forum/showthread.php?t=3897
      www.tigeaz.com
        Yah seems like that rival is everyones answer but we rode behind Erik Rucks 24ve and he had about 5000 pounds in it we just hate filling and unfilling the bags
          You could always go with lead
            Two enzo sac's (1400 lbs each appx) and a open bow fat sac (1000#)
              The Rival system would work with the layout dabell just mentioned. You will lose all your storage, but no sacs in the aisles.
              http://wake9.com/
                Surfdad is using some 3800 gph pumps so fill time will be short.
                  with the enzo sacs you can hook up two tsunamis at once to fill or transfer over if you have a spare enzo sac opposing side. i know my wave starts to look good with factory system full and an enzo sac in the corner. not to mention the peeps
                    Are you looking for Surf or Wakeboard wake?
                      The last I knew, he was only using one ballast puppy and able to switch between the sac's that he wanted. I saw his layout in July.
                        I think you're thinking of someone else. Larry Mann is the one who's got the 3800 gph ballast pumps.
                          You're probably correct I knew someone posted this and I think it was you. Thanks for the clarification Dog.
                          Either way, it's a darn load of water
                            I think the term you're looking for is fire hose
                              really? I have a 20V and the wakes are huge. Running 1800 ballast plus the folks. Taps at 4 or maybe 5. never 8.
                              You just want a bigger boat
                              I have been riding on a Bu 247 and a 07 220 super air. I would have to say its pretty close to mine. Thing is with bigger boats you may have to ride a little faster once you load them up.
