Ballast for 20v
    Ballast for 20v
    I want to get ballast for my 06 20v and think i am gonna start with just some bags and a portable pump. I was wondering what i should get and if it is hard to drain the bags if they are in the back lockers? And where did the rival website go or if there are any other good systems?
    Fly High Pro X series sacs and a Tsunami pump (or two) will get you started. Are you wanting to use them for surfing or wakeboarding or both? Maybe try the v-drive sacs to start with (400 lbs each I believe). I got last years models that are 550lbs each and it made a huge difference. The Tsunami pump is so fast that it makes filling and draining pretty easy.
    Also, if you get a discount with your dealer, try them first.
      both
      is it hard to drain them though when there in the lockers
        I don't know if I would go too far over 1200 lbs in a 20v. Was with tigeblue one weekend with 6 adults, 1 600 lbs sac, 22 mph, and TAPS between 4 & 8 (wake looked so much better with TAPS at 5). The wake looked very nice.
        IMO, Timmy! is suggesting the correct sacs for your boat.
        Contact anhaney, he might have some type of connection also
          Originally posted by byfor5 View Post
          both
          Just open the locker doors and attach the pump to the bags and then plug in the pumps.
          anhaney also has pumps. The same one's that Timmy! suggested.
            http://www.wakeside.com/page/w/PROD/...drive_sac_W701
            would those work pretty well
              That is what Timmy! suggested.... Yes... Again, hit up anhaney with a pm and ask. I think he might be able to get a better deal for you along with 1 or 2 tsunami pumps...... Good luck...
              Just remember, make sure you clean your wake up with TAPS. IMO, you don't need all that weight and then TAPS at 8. IMO, it will look better at 3-6.....
                You'd be surprised how much weight you can pile in to a 20v. I'd get the Fly-High bow sac and the V-Drive sacs. You're going to want at least a 50/50 (recommend 60/40) front/back distribution. I'd pick up a portable 85 or 150 that you can move around or get some lead weights. Also, multiple pumps can mean the difference between 5 minutes vs. 20 to fill. I have several LaunchPad Link sacs, 2 Uber pumps and 1 Fly High Bow sac w/ Tsunami pump. We're loaded to bear in less than 8 min.
                  I would deff. say go with the Fly Hi sacs. If you are going to surf as well as board, try to get a combo that will give you the wake you need for both with minimal sacs. Once you got it dialed in, the plumbing is easy to finish up the install and you will have an automatic ballast system.
                  Anybody running the bow sac in a 20V? how much do you think it holds in a 20V?
                    The only one I know that runs a 20v is tigeblue. He only has one 600 lbs sac and puts it in front of the back seating area. We also has one person (125-200 lbs person) sit in the bow. He has a very nice wake when taps set to 5.
                      Here is a thread about some ballast in a 20V
                      http://www.tigeowners.com/forum/showthread.php?t=3833
                      and another http://www.tigeowners.com/forum/show...ht=ballast+20v
                      some more light reading http://www.tigeowners.com/forum/show...ht=ballast+20v
                      one more http://www.tigeowners.com/forum/show...ht=ballast+20v
                        do you think it is necessary to do some type of quick release like...
                        http://www.wakeside.com/page/w/PROD/...x_fitting_W744
                        or
                        http://www.wakeside.com/page/w/PROD/...x_fitting_W743
                        with
                        http://www.wakeside.com/page/w/PROD/...x_fitting_W741
                          The quick release fittings come standard on the Tsunami pump and the Fly high sacs so if you stick with all of that you won't have to buy any additional connections.
                            Yeah, they rock!
                              One more thing, you will be amazed at just how fast the Tsunami pump is! Still in awe every time we hook it up!
