Found out some very interesting info today
If you plan on having your dealer Install the Tige ballast on a Ve or RZ after the boat is delivered, good luck.
It seems that the Ve's and RZ's ordered WITH OUT ballast have deeper transom storage coolers then these models ordered with ballast and the hard tanks will not fit between the cooler and the floor.
There was some talk about whether or not the tanks would fit in with out removing the engine...........they look like they will but the alt will have to come off to slide in the starboard one. The port side looks like it will go with out much problem but this is only half the battle because you would have to exchange the storage coolers for the shorter ones. That is a whole nother thread
