bullet pumps
    bullet pumps
    check these out. how do you change the pump direction on these pumps. is there a switch, it doesnt look like the blue fitting can attach to the tubing in order to fill the sack. the way it is set up is only good for emptying sacs unless there is a switch on the pump itself. see if you can give me some light.
    http://cgi.ebay.com/FAT-SAC-1100-GPH...QQcmdZViewItem
    You don't change the direction. You put the PUMP in the water and the hose to the sac to fill. You put the pump with the blue fitting on the sac and the hose overboard to empty. Try the fatsac pumps with the quick connect fittings. Saves a lot of water spray.
    This is just the pump.
    http://www.wakeside.com/page/w/PROD/...h_ballast_pump
    This is with the quick connects and hose. That works perfectly with the FlyHigh Sacs. Its 60 bones more, but the fittings and the FlyHigh stuff is VERY high quality. Its not a cheap plastic, like it looks. I think it is worth it if you just have 1 or 2 pumps and do it manually. The ala carte pump is good to build a system.
    http://wake9.com/
      well i know that you dont change the direction , but i just wondered becouse there is no fitting on the end of the tubing itself. would i have to buy a barbed fitting to go on that end.
      i allready boughth my fat sacks and the only prob with them is that you cant use a quik release on them. the sacks only have the threaded drain plugs on either side. i was able to feel them this week with my freinds pump and the blue adapter he had and it worked just fine. if your quik it doesnt spray much at all
        Fly-High makes quick release valves for manual filling. part# W734 goes on pump, W738 goes on pump hose, W730/W739 go on the bag and should have come with the bags, did mine
        www.fatsac.com
          the winning bid was for 51 bucks for an 1100gph pump.
          you can get a 1200 gph pump on wakeside.com for 30 bucks.
