Does anyone have pictures of where to make the hole where the fill and drain hoses come up from in the bow?
Rival Ballast install
http://www.tigeowners.com/forum/show...ighlight=rival
This thread should answer everything you need to knowSuccess is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
The drain and vent hoses go from the bag in the bow out the side. I ran the fill hose on top of the gas tank and came up in the storage area before the under bow seat storage. Drilled a hole in front of the vent hose hole, and then in the wall to get the hose to the bow. I will not have pictures until next week. Not sure how Talltigeguy got the fill hose to the bow.
Hope that makes sense.Let it be!!!
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
I initially ran the fill hose up over the engine compartment divider and then along the starboard side all the way to the front.
I just rerouted it on top of the gas tank and then up where the steering cable goes through and then to the front. No extra holes drilled either way.
So mine does make a journey up to the level of the bottom of the dash board. I do not think it has affected fill times at all.Be excellent to one another.
