The reversible pumps will not allow water through. The aerators are faster. I talked to the guys at make a wake and for what I am planning the fill times would be about 19 minutes. With the aerators I should be about 8 minutes. We will see!!!
My Ballast System
Here is the answer to the gate valve switch:
GM uses a latching timer relay with a momemtary switch for their rear defrost sys. the timer will power the gatevalve long enough to fill the bags and then de-energize. Does anyone know if these g/valves are self closing?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostHere is the answer to the gate valve switch:
The GM type for the defroster is not a permanent latch, but has a timer on it, so the latch is broken after x seconds, and then closes again. You can create a latching circuit like this with 3 relays farily easily. This one would have a coil to return it to its normal position after the latch is broken.Last edited by spharis; 02-13-2007, 08:34 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
No the RV gate valves require an action to close also.
Spharis
I will definately be contacting you in the future. Thanks for the info. I still hate electricity though. Ever since I worked in a restaurant. I was cleaning a walk in freezer, I took a wet brillo pad over a broken light socket exposed wiring. I definately felt the power. I was smokin!!!.Let it be!!!
Originally posted by xpjim1 View PostThe reversible pumps will not allow water through. The aerators are faster. I talked to the guys at make a wake and for what I am planning the fill times would be about 19 minutes. With the aerators I should be about 8 minutes. We will see!!!http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by xpjim1 View PostI bought the aerators. 6 Tsunami's 1200 GPH
which cost more: 1 reversible (+ check valve(s)) or 2 aerators?
I saw 2 aerators for less than 1 rev but dont know how the flow rate compared as one was in GPH and the other in GPM and I didn't do the math.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by spharis View PostSomeone had posted questions about these before, and I asked him some troubleshooting info about them. Those are a whole 'nother can o worms, but they can be made to work too, although you so not have enough free banks.
Thanks!
Spharis
Not Sure I am waiting for someone to send me another document that did not use relays but tied all the grounds. Not sure what that means but i think it had 6 power wires from the switches (1 to each pump) and 1 negative from the switches which all pumps were tied into. This is for the ballast pumps only as they do not have a gate valve. On the switches the negatives were all joined. Hope that makes sense.
I want to do what will work, is easy and not screw with the boats electrical. I just do not know enough here.
Back to work. I will post the other document tonight. have to get back to workLet it be!!!
Originally posted by spharis View PostThat's similar, but a different type (the type I would use actually). The RV style xpjim has opens and stays, or closes and stays. It has a reversible motor that creates a latch when it has input. Once it is open the latch breaks so the motor stops turning, but the gate stays put. No coils in it to return it. Same process for closing.
I think 2 timer relays will work, 1 to open when a fill is turned on, and 1 to close gate when fill pump is turned off. In other words, an "automatic" gate valve.
See my sayMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostYah, I dont want a permanent latch, I want to energize the gate long enough to open it with out having to hold a momentary, or turn on/off a toggle.
See my sayhttp://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by xpjim1 View PostNot Sure I am waiting for someone to send me another document that did not use relays but tied all the grounds. Not sure what that means but i think it had 6 power wires from the switches (1 to each pump) and 1 negative from the switches which all pumps were tied into. This is for the ballast pumps only as they do not have a gate valve. On the switches the negatives were all joined. Hope that makes sense.
