For the gate valve. A little push up to open the gate to feed the fill pumps. After filling a little push down to close the gate so the bags do not keep filling while under way. This is if you are using aerator pumps. If you are using the reversible pumps this is not needed
My Ballast System
Originally posted by chpthril View PostWhat will the 1 momentary be for ?
brain fart maybe, but dpdt and spdt mean what ?
SPST - single pole single throw (one input, one output...a traditional switch)
SPDT - single pole double throw (one input, two outputs)
DPDT - double pole double throw (two inputs, two outputs)Last edited by spharis; 02-13-2007, 08:00 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by xpjim1 View PostI could not find printed actuators to match my switches. I ordered these from Lee to use. The picture is not my dash as my actuators are slightly different. The switches you will need one momentary (on)-off-(on) DPDT and 3 regular rockers on-off-on either spdt or dpdt
I think you have your switch requirements backward. The ballast fills should be momentary, and the arm should be toggle, right? I wasn't aware the ballast switches were on offs.......I think I'd rather have momentary type. Seems like the coil on the fill gate would need to stay energized to stay open, and close when relaxed. Who knows though, Tige' could have gone through the trouble of making a latch circuit there, or they used a latching gate.....those are expensive though. I would have wired it so that whenever a fill switch was engaged, the gate opened, and then when it was off it could close again. Less to remember that way, and it is automatic.
If you want to really get fancy, I can show you how to build latching relay blocks so you get auto fill and empty by just pushing the buttons. You will need a level sender for each sac though.Last edited by spharis; 02-13-2007, 08:05 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Spharis,
Doesn't momentary mean that it only moves when the switch is pushed on, and the switch then moves back to its normal position when you let go? I think that is why he wants a momentary for the gate valve. You wouldn't want to have to hold the switch to get the ballast pumps to work.
Help me with the proper electrical terms.Be excellent to one another.
Just help me!!!Right now i do not think I could handle fancy.
Luckily wiring will be towards the end. I have ordered 90% of the parts. Family and friends were nice enough to give me some gift certificates for some of the parts.
Hopefully the thru hulls come before saturday so I can start drilling the drain and overflow holes in the boat.Let it be!!!
Originally posted by xpjim1 View PostHere are pictures I took from other DIYer's
The 1st is lighted DPDT for the gate valve
The 2nd is lighted DPDT for the fill and drain pumps
The valve is obviously a latching type. Are you gong to use a valve, or are you going to use reversible pumps?Last edited by spharis; 02-13-2007, 08:18 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
If you want to really get fancy, I can show you how to build latching relay blocks so you get auto fill and empty by just pushing the buttons. You will need a level sender for each sac though.and it pissed all over me.
I dont remember an "arm" type switch either, unless it was on the dash.
I think the way to go would be to have the gate valve powered off the fill pump switches so you kill two birds w/1 stone (providing the gate is self closing when de-energized)
Having little experience in this, I would have thought that these pumps would not allow flow in either direction when off thus no need for a gate valveMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
I would use momentary for just the gate valve, you don't want to have to hold down three switches for 5-7 minutes to fill or empty the bags. Are we talking about the same thing?
I sometimes forget to turn mine off, but luckily the type of pumps used are a little forgiving when run dry.
Chpthrill,
they do allow flow under pressure. The turbine or fan inside the pump that pushes the water rotates freely when there is no power to the switch. It flows better forward than back, but can even flow backwards.Last edited by talltigeguy; 02-13-2007, 08:17 PM.Be excellent to one another.
Originally posted by Moki View PostUnfortunately, my switches are not 3 way, they are push button on/off
I don't have a lot of space on my dash and will probably mount them on the driver side panel.http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by talltigeguy View PostI would use momentary for just the gate valve, you don't want to have to hold down three switches for 5-7 minutes to fill or empty the bags. Are we talking about the same thing?
My previous post made the assumption the gate was not a latching style, as those are pricey. the latching styles are a yes on the momentary for sure.
On the fills, I think I would prefer momentary, but I don't know as I've never had ballast beforeI thought you would be able to fill faster than that.
[]) [] []V[] [])
Originally posted by xpjim1 View PostI am using a RV Gate Valve like Rival does. It runs on a momentary switch so I just kept it the same. The regular rockers for the fat sacs will work. When water starts coming out the overflows, just flip the switch off. I do not want to hold the 3 switches down while filling.
On the RV gate, it is a reversible latching motor. Triggering voltage one way willlatch it to open until it fully opens and breaks the latch. The wires are flipped on the switch so it closes in the same manner.
The little "l" on the ground in the photos you posted is for the lamp in in the switch.Last edited by spharis; 02-13-2007, 08:26 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
