2006 24VE specs
    2006 24VE specs
    So I just purchased a 2006 Tige 24ve and have been looking for places to get info on my boat. The only thing I have been able to find is the weight and few other specs. They also do not have specific manuals for each individual boat. I know I am new to owning a boat but I can't imagine that all 24ve boats are the same with the same manual.
    Also wanted to be able to look up parts and part numbers for my specific boat and have not been able to find a place to do that. I would like to know some specifics on the engine I have in my boat. What does everyone recommend? Is there a place I look up my hull/serial number and it will give me that info?tige.jpg
    I’ve got a manual I can send you. PM me your email address.
      I assume its a marine power engine that is what we had in our 06 24ve. Here is the Marine Power 5.7L engine manual: http://marinepowerusa.com/wp-content...ice-Manual.pdf
        I haven’t seen the Rasta Tige in a while! The manuals are very generic. I used mine exactly once and that was to send it to Tige so that they could scan it and have it on file. Your best bet is to ask questions here. This site is 1000x more helpful.
          Ah the fruit salad boat. I remember it going down the line. From what I recall it had yellow uprights. Maybe they had issues with the powder coating or something. email justin at tige.com the hull ID number and I will send you some information on it.
          Oh Yeah!
            I was quick to respond. Yours was the Rasta boat and this was the fruit salad boat. Can't recall the story on your boat but I will think about it over the weekend.
            Oh Yeah!
              Dealer: What color would you like, we have 12 to choose from?
              Buyer: Yes
                one of those wild color schemes was a guy on here that was looking for it again. iirc it was called skittles and was a 20ft'er.
                2012 22ve.. RIP 4/17
                2014 Z3.. Surf away
                  ^^^That was the Candy Corn 20v.
                    ya.... your right . where did I get skittles? I know I've seen that on here before.
                    2014 Z3.. Surf away
                      Ahh, Skittles, Candy Corn, they’re all pink in the middle.
                        You’ve got to fashion some dreads to hang off the bimini, you know, for extra shade.... Complete the look maaan!
                          Thanks for all the info. I will be contacting tige to get anymore info on this boat. Thanks boone for the manuals. I might only allow reggae music to be played on this boat. I have only had it out 3 times but and it ran well. Need to replace some Johnson ballast pumps and bilge pump also. While I am in there I am also going to replace the bilge blower motor. Any suggestions on a good place to pick up some of these items.
                            Stock ballast with white soft sac in bow and hard tanks across the transom? If so, id consider the whole ballast setup before replacing any ballast pumps. The stock ballast is ok for a beginner wake boarder, but insufficient for surfing. Larger capacity sacs with stock pumps = long fill/drain time.
                              the man you need to pm to get parts for your ride posted above ^^
                              he will hook ya up with everything you need in the ballast department and customer service to install is second to none.....
                              2014 Z3.. Surf away
