I have a 2008 Tige 2008. Seems to me to get the most use of weight on the Port side I should move the batteries just up from center cushion/storage compartment. What is everyones recommendation?
Best Place to Move the Batteries
Depends on hoe you weight the boat and which side you primarily surf. Remember a typical battery can weigh in around 50lbs and are about the same volume as 2 gallons or water @ 17 lbs.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
two 50# bags of lead (steel shot) will do itMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Put the battery weight where it will do you the most good, keep it centered so offset weight isn't required, and use otherwise unused space to preserve your storage space for other things:
We have a custom sac thats designed to go over the battery and TAPS motor boxs. No need to move them. However, they do need some reinforcement.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
