Trying to find the front and rear ballast size for my RZR. Rear lockers have separate soft bags on each side and the front has 2 soft bags as well. I think it is 400 (200 each) in the front but i am not sure of the rear.
2013 TIGE RZR ballast size
For a 2013 RZR, the rear would have 250 sub-floor hard tanks and 350 above floor sacs with the Surf level ballast option. IIRC, the bow was only 400 total. The larger models got the 800# total Pro level bow bags.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
chp is spot on. what came in my 22ve as well. I have been told the pro 800lb was only on the rz2/4 and z3. the 22/24ve, rzr and z1 were only the 400lb due to the size of the storage areas. I would not have been able to fit any more than the 200lb in my 22ve. those hulls don't need a lot of bow weight tho. they like it in the rear
if you want the hookup, have chp sell you larger bags and an extra fill/drain pump for each rear bag. best mod I ever did to the boat was the larger rear surf sack.2012 22ve.. RIP 4/17
2014 Z3.. Surf away
great
Originally posted by Ironrequiem View PostI have a 600lb port rear stock bag from 2015 R20 Tige.
If interested $120.00 shipped to you.
Thanks
Originally posted by Lukesanden View PostCHPthril, I have not seen any hard tanks in the boat at all, Just the bags. Would that mean there is is only 2 350lbs bags in the rear? also what you you suggest for a bow bag? W711 or 2 separate bagsMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Are you in need of a bow sac to replace a failed bag or more weight? I do not think the W711 is going to be that much more. Id consider a couple lbs of lead if looking for weight.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Then the W711 is a the way to go. We had a lot of owners make the swap. its a minor mod.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
