I want to design a system to measure the fill level of my ballasts bags in my system. I installed the system in my 2000 21V with the supply help from chpthril
. This season I have researched options of designing a monitoring system for my ballasts. I have seen 2 possible options and was wondering if anyone has solved this problem or has suggestions. Timers won't work for changing a fill setup except for possibly the initial one, starting from empty.
One option I have come up with is using a flow sensor and just monitor the water in or out using Arduino or Ras.Pi system to display and follow. The other that I have found uses a pressure sensor placing on the bottom of the sac, and calibrate the pressure of the full ballast to an empty one, then using Arduino to display and monitor. Hard tanks would make it much easier, but I have what I have.
All input welcome. I will keep an update on where I go form here.
