I need to get some more weight in the boat. I am looking to remove the factory port bag and install a custom bag. Would the new bag be plug and play or would the dealer need to reprogram the fill time for the new larger bag. Any recommendations on who has the best prices on custom ballast bags? Also looking to get some lead weight for added ballast, so any advice on where to get the best prices on lead weight would be helpful as well. Thanks in advance!
2014 RZ2 custom rear port ballast bag
A ballast sac swap on that boat is fairly straight forward. Not quite PnP but not a major job.
You can reset the timers yourself, no dealer access.
Mikes Liquid Audio has the best price and sacs.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Take a look at pop-products.com, they have 40lb bags, stitched handles, 520lbs $468 to your door.
Shell is made from vinyl so clean up is easy if needed.
Larger and smaller quantities available.
Have worked very good for us.
