Help! 07 24ve stock ballast system problem.
    Hi all,
    I’m going to look at a 24ve this weekend to possibly buy. The owner says the stock rear ballast system was working last summer but the last time he showed the boat the prospective buyer ran both fill pumps at the same time and now the port side fill isn’t working.( the drain pump still works)
    So here’s my question: in the stock system can you run both fill pumps at the same time? Is there any reason running both or all three fill pumps together is a problem?
    Also, if one fill pump stopped working it’s most likely the pump failing or a fuse or breaker tripping right?
    Anyone have the manual or know how that system operates and what I should look for? I’m assuming replacing a fill pump is pretty straight forward. Thanks!
