Hey everyone, I’ve been reading through a lot of existing threads on the 24V, and I haven’t really found the answers to my questions, so I’m hoping to find some 24V owners with some insight. I got a great deal on a ’05 24V last July so we sold the Pontoon and spent the rest of our summer surfing! The boat puts out a pretty decent surf wave with my current setup, but it’s very manual and not great when I have a small crew.
Current setup came with the boat:
2X 750 LB Fat Sacs for the back
Bow sac – I’m guessing 450 LB but I think I’m only getting it half-full due to space limitation
Mission Delta – I purchased on the advice of a buddy with an older Malibu Wakesetter
If I fill all the sacs it’s hard to get the Delta in the right spot, as below the lip is a little lower than it should be, and above the lip is out of the water a bit and creates a lot of spray and doesn’t appear to function properly.
I’m looking to upgrade my wake enhancement in the off-season and I’m not exactly sure what I should do. I’m planning on taking it to the Tigé Dealer to have the Taps looked at, as it started to not work towards the end of the summer. I was going to ask for a quote from them on having the surf tabs (Go Surf Assist or something similar) installed. Any suggestions on what I should do for ballast? If I plumb in the ballast, is 750 lbs per side in the back good? Can I get more weight in the bow using Steel Ball ballast bags at 50 lbs a piece? I read something about 60% / 40% split, does that mean I’m weighting the back too much?
A couple of notes, I’m not particularly handy, so I’m not planning on installing anything myself, and I don’t want any of the ballast exposed when I’m loaded up, so I’m only looking for storage compartment solutions. I’m also not afraid to spend a couple bucks, if it improves my wave and makes setting up easier (modifying is cheaper than buying new), any advice would be greatly appreciated. Also, if anyone has a suggestion for installers in Oregon for this stuff, that would also be considered. I’m headed to the Portland Boat Show next weekend, hoping to get some advice there too.
